Front Top mount set up.
1 Post
I have this front top mount set up in my '90 C2.
It looks similar to the Rennline unit. The bolts/fixings look like the aluminium has oxidised.
For cosmetic purposes, can I just get these bolts replated?
Replace one at a time and torque them back down again and you shouldn't run into any issues. Take one out to find out exactly the size you need. As long as the others are torqued down properly, you will be fine to remove one without disrupting your camber.
