964 Forum 1989-1994
engine harness
Old May 7, 2017 | 09:03 PM
wallra's Avatar
wallra
Default engine harness
Any one remove their engine harness from ecm to engine? I'm install stand alone and was trying to see where the harness run's so I could see how much of the carpet to pull up. It looks like it run's down the drivers side just need to know where it runs across to go through the fire wall out the passengers side.
Old May 8, 2017 | 09:33 AM
Gus's Avatar
Gus
It goes behind driver side, up the driver door side of the step up to the rear seat then along the angle made by rear seat and rear panel through the fire wall with a large rubber grommet. If you start in the rear corner behind driver seat (left drive) that is made at the junction of rear seat area, rear driver side wall and the rear engine panel you will find the wiring harness. ECU and O2 sensor wires. The harness behind passenger seat (same area is mostly lights. Do you want pics or is this clear enough??
Old May 8, 2017 | 01:19 PM
wallra's Avatar
wallra
that clear enough. Thanks.
