Re-charging a flat a/c system
Let's just take a look at the high side for a moment:
High side, say at 25C or 77F ambient (air temp surrounding the outside of the car), there could be a range in pressure from 10 bars to 15 bars or 145 psi to 217 psi. Yes, when you think about that you got a spread of 72 psi. Let's cut that in half and say the middle would be 145+36 or 181 psi at 77F ambient. On the non factory chart, nearest ambient reference is 75F, and here you have a range of 150 to 170 psi; middle range of 160 psi. So things are not too far off: factory 181 vs other chart of 160 psi with a 2 degree difference between the two.
The factory manual is suggesting the observation should be performed with a perfect vacuum (meaning a liquid flush of refrigerant using the factory "SECU", then pulling a vacuum with same machine) 840 grams of R134a, clutch engaged, windows and doors closed, max ac thermostat setting, evap blower at 4th speed, and after system has been running like this for 10 minutes and pressures noted at 2000 rpms.
Higher rpms do raise the high side pressure and drive down the low side.
So the question is with respect to the alternative pressure chart you have....what are the conditions when those pressures are observed?
Sorry to hi-jack, but does anyone here obtain the vent temps from the factory chart? I just did a test today using a thermocouple that reads accurately at 32F and 100F. Ambient was a very humid 87-88F, recirc on, max fan speed, center vents only:
30sec after a cold start I get 70F at idle
30sec of 2k rpm I get a steady 65F
Compare to my wife's 2015 Mini:
60F at idle, 55F at 2k rpm.
Big window unit AC in the house: 55F
And the chart from 199x for a non-optimal system says that we should be seeing vent temps of 45-52F? Yeah right!
Update- I did a little more reading. I am going to go pull the inner fender liner out and measure the inlet and outlet temps of the dryer. Maybe the driers clogged?
That part R&R they were thoughtful of in the design of the evap system.
Very new to me 1990 964. I have receipts for a new A/C condenser and R134 from about 18 months ago. I also see the red and blue R134 caps on the compressor so I believe it was converted to 134.
A/C blew cool (not cold but cool) when I test drove and did the PPI. It has mostly been sitting in my garage as I go through and fix shoddy previous repairs and replace missing fasteners. This past weekend it was hot and A/C was not cooling. Quick inspection revealed the compressor was not kicking on.
I have done no other tests. Seems like the quick and easy fix (even if temporary) is to pick up a 134 kit from the auto parts store and recharge the system I just want to be sure I don't damage it by doing so.
Based on the other work I have seen, previous owners / mechanics did everything the cheapest, fastest, easiest way they could. I would not be surprised if it was under-charged from the start. Also, because it is now not working, I believe I probably have a slow leak somewhere. I say slow because based on the receipts it has taken a good 18 months for the system to stop working. I can live with a DYI recharge every 12-18 months if that will keep me cool until I can pull the entire system and do a proper R&R.
TIA
You would expect that you could simply add refrigerant (referred to as 'topping off') because in theory what ever existing refrigerant is in the system should prevent outside atmosphere from entering the system. However, that tends not to be the situation all the time. So, smartly you evacuate, charge and test.
Once you do get the system charged you should try to track down the leak with an electronic leak detector. Common leak points are:
TEV
Evaporator (sniff the vent and drain tube)
Compressor manifold, schrader valves and nose seal
2 lines on the compressor
There could be other leak sources but the ones above are typical.
What ever you do, don't put leak sealant in the system.
And, although the system has a low side pressure cut off switch (prevents compressor clutch from engaging when system pressures are low), its not a good practice to run the system with low refrigerant levels; that model compressor does not hold up
well to it. If the compressor starts to break down (toss off metal) the time required to properly liquid flush the system is quite long.
On a second note, I believe I found the restriction in my system. The condenser is plugged up. The temp going into the condenser is 135F and over a 6in section of condenser in the first vertical row where the temp drops 25-30F and only drops 5-7F over the remaining 13 rows. I measured it with a thermocouple but you can actually feel the heat difference with you hand. I will report back once I get it take care of.
TEV
Clearly in the future I will need to pull the fender liner and gas tank and replace the drier and expansion valve and all of the o rings and possibly the evaporator etc...
But in the mean time, for this summer, I can simply add some 134. Right?
