Parts Help ABS Wiring Harness
I'm looking for source for the rubber mounting grommets that go around the abs/pad wear sensor wiring harness. They secure the harness to the rear suspension and the front inner wheel arches. I have searched the PET and can't find a separate part number.
TY, JF
TY, JF
I just inspected my ABS Speed sensor wiring. Due to heat in the engine and wheel arch all the white barrel connector are dead. I just purchase on ebay, 4 complete wiring harness for front and rear wheel. Can you advise how to replace?
Front harness :
I cannot locate inside the trunk where the white barel connect ? Can you tell me where it is?
Rear Harness
Where the white barrel connect? Is it inside the engine bay? is it inside the car? is it on the floor? and where?
re : In case the replacement is too hard, do you think it is possible to cut the existing damage barrel with a piece of wiring cut the same distance of wire with the replacement barrel, do a nice and clean wiring soldering and insulate again?
Front harness :
Rear Harness
