How lower engine/gearbox for starter removal
Sounds like a good idea, but I have to admit I don't know how to do that and I'm also concerned that I don't lower the engine too far.
Thanks for any help and advice you can give.
Jim
Lead Rennlist
Technical Advisor
Lifetime Member
This I DO NOT recommend unless you are properly equipped and have a couple of people present. I have not heard of the need to lower the engine to remove the starter. All I can say is take a closer look at what might be in the way.
Ciao,
Adrian
964C4
I did this job myself and only removed the axle and diff lock actuator. The top bolt is a pain but you can get it with the right extension on your allen key socket. Try using a knuckle it may help also.
I did mine without dropping the engine/box - the top nut is a pain to get to, and you can only get on it by feel, but it's just about having the right tools - you definately need a universal joint - this makes it much easier.
Have a look here: http://www.964c4.ukf.net/starter.htm
There are some pictures that might help.
Cheers,
Pete. 90 C4 Coupe.
However, from everyone's comments, it doesn't seem like I need to remove the heater fitting or lower the engine. I thrown a few different combinations of ratchets, extensions, etc. at it already, but my toolbox isn't empty yet
so I'll keep going. Thanks to all for the responses. I'm not new to working on/restoring my own cars, but I am new to working on my Porsche and this is a great site!
Jim
Here is my post:
https://rennlist.com/forums/showthre...threadid=95843
I used the instructions from here:
http://www.porsche964.co.uk/technical/starter.htm
If you still have it... remove the under tray... might want to keep it off... (start the debate again)
Need to undo the drive shaft from the transmission (but no need to completely remove it.
Remove the slave cylinder.
Remove only the heater hose.
Use a 10mm in-hex with a 3" extension to remove the upper starter bolt.
voila!
Yes remove the aluminium fitting that the hose was connected to. There are 2 nuts holding it on. It allows a lot more access. I used a 10mm hex key with the right angle ground off. I slipped a 10mm ratchet spanner over and spent ages trying to get the hex key in the cap head. It is possible and the ratchet spanner requires less space/movement than a socket hex to break the bolt free.
And no with patience!! you do not need to drop the engine.
Good luck.
Richard 1990 C2
Put the car up on jack stands with the rear in the air...but not too high, just enough to provide a comfortable amount of space to work in.
Place floor jack pad under the motor, where the case seams together to support the engine then undo your motor mount nuts...you don't have to undo them all the way!!
Lower the engine the inch or two that this allows (***not removing the nuts all the way) and you will have better access to that allen nut...a 10mm allen socket is required.
You won't need a floor jack if you're careful about NOT removing the nuts all the way...you can actually lower the motor by just loosening the two nuts up on both sides, furthest rear. Just be careful, if you get one of them off - OOPS!!
I also do this when I bleed the clutch slave cylinder...again, while not required to perform the task, it does make it a bit easier.
I plan to continue my efforts to remove the starter without lowering the engine, but just in case, or for future reference, can you tell me where the motor mount nuts are? This would not be something on which I want to make a mistake.
Thanks, Jim
Basically, it turned out that I needed to apply a bit more torque. Being a bit of a tool junkie, I have quite a collection of ratchets, bits, universal joints, etc. Nonetheless, I could not get an angle where I felt I could apply sufficient torque without being concerned about stripping the hex nut. I had not yet attempted to lower the engine and was worried about doing so. I was ready to throw in the towel and flat-bed it to my mechanic - if he stripped the nut, it would be his problem.
I was giving it another try with a stubby hex socket, universal joint, extension and 3/8 flex head ratchet when I heard a CRACK!!. It sounded like a gun went off; I thought for sure I broke my ratchet. But I pulled the ratchet off and everything seemed OK. I tried again. CRACK!! Same routine - pull ratchet off, seemed fine. I tried again and the NUT MOVED! Less than 5 minutes later the starter was on the ground. I don't think I ever loosened a nut that tight that didn't end up stripping the nut or shearing the bolt.
Anyhoo, there were other adventures to come - like the rebuilt starter with the wrong solenoid and the second rebuilt starter with the slightly mushroomed shaft. But I eventually got it back together and its on the road again. And I just located a genuine 964 Turbo spoiler and decklid, but thats another story....
So thanks to all for the help and advice, it was very much appreciated.
Jim
I've since come across a replacement starter motor from Cambridge Motorsport, which is much smaller. This makes it a doddle to fit and remove, and it's cheaper than a recon Porsche item. Also it's geared to give more torque.
The one I saw was supplied by Autofarm (www.autofarm.co.uk).
Cheers
