I've got an optima yellow top. Perfectly happy with it.
Fwiw. Batteries are not, in general, the quality they once were, in terms of lasting a long time. But when they function, they seem to function better today.
I haven't had an issue w my optima yellow top. Ask me in five more years...lol
I went with a Duralast Platinum EFB model. I had to Google “EFB”….that wasn’t a thing I recall from 5 years ago when I bought my last battery for the 964.
I wrote this Dec 2021.
It's now June 2022, and my Yellow top will barely start my car. Once it's been driven a bit, it'll start all day long no problem, but at night, i put the car on the tender, the tender reads the battery is fine, lowers the amps on it's own, and then the starting amps are almost zero within a few hours. If I trick the battery, one hour before the morning start, unplug and re-plug the tender, the battery jumps to life.
So - is it a bad optima yellow top that should be replaced under warrantee? or do i risk another and just go to Autozone for a new Platinum...
Three different tenders - the battery is toast - Though if you look up YouTube vids on bringing these back to life - you can put it in series with a known good battery and then hook the tender and restore it - but is that something anyone really wants to bother messing with?
These battery issues are very frustrating - you'd think someone would come along and just raise the quality back to an acceptable standard. And don't get me started on the lithium garbage - after they dumped a 10,000 gallon water truck on our race car a couple years ago trying to put out the battery fire, i'll never go that route in a street car. Why those are even legal is shocking to me.
IF you guys are ever interested in Lithium you can try one of our Antigravity Batteries. The have built-in protections so you cannot damage the batteries by over-discharge, over-charge, short circuiting and much more. The coolest feature is the built-in WIRELESS Jump Starting so you will never be stranded again and you won't even have to access or see the battery if you ever came back to it dead... just press the provided wireless keyfobs start the car and drive away. Last they have a lifespan of 8-10 years and weigh from 6 to 12 pounds for the sizes that work in a 964.... but they are more expensive than a lead acid battery.
I've had wild success with generic AGMs. I park my dailies outside and drive them thru 10deg F CT winters. My E30 had a Sears AGM, my 964 has a Napa AGM. Spider sense tells me they're all made in the same place but I got nothin to back that up. Both crank like they're mad as hell. I'm 2yrs into the Napa, believe I had that Sears for 3 when I sold the car. Both at or below $150.
If you are going weight weenie I can endorse Optima equally enthusiastically. I have tiiiny lil PC680 on my Alfa GTV which has a high comp 2 liter and sits for months at a time. Cranks like a banshee and very tolerant of abuse. Many times and I've deep-drained the battery while fiddling with the car. Also very inexpensive believe I paid around $125.
