964 Forum 1989-1994
Oil gauge not working??
Old 11-04-2003, 10:10 AM
Roygarth
Roygarth's Avatar
Default Oil gauge not working??
I don't think mines working....put oil in....level increases on dipstick but not on gauge??
Before anyone asks I think I am fully conversant with oil filling procedures -engine temp, level ground etc etc!
Anyone come across this?
(Presume 993 is same as 964)
Old 11-04-2003, 11:06 AM
Richard H
Richard H's Avatar
I assume 993 is the same as 964, therefore I expect the oil level sender in the oil tank to be kaput. Quite a simple diy job, there is a write up on John Mile's site. Mine was very irratict, obviously some bad spots on the resistor track.
Richard 1990 C2 (oil level sender replaced about a year ago)
Old 11-04-2003, 11:15 AM
DaveK
DaveK's Avatar
My sender had died when I bought my car - but this meant it always pegged at total max (off the scale) as long as the ignition was on.
Old 11-04-2003, 11:27 AM
johnfm
johnfm's Avatar
I think kaput oil sender indicates full - not empty. Impressed that you can get any sensible reading from the dipstick!!!
Are you getting the engine hot enough?? I know that I never get a reading on the gauge until oil temp is approaching '9 o'clock'.
Old 11-04-2003, 12:14 PM
Roygarth
Roygarth's Avatar
Thanks guys.
Wondering if mine is actually using a lot of oil and is right down on gauge and I am misreading it on dipstick?
When I bought car 3,000 miles ago leakdown result was 'less than 5% on all cylinders'. Does this imply oil consumption should be low?
Slight tangent here, but oil consumption, as opposed to leaking, is via it passing into cylinder and being burnt?
Old 11-04-2003, 12:30 PM
John Boggiano
Lifetime Member
John Boggiano's Avatar
Piers,
Are you sure your dipstick is working?
Old 11-04-2003, 12:49 PM
Arjan B.
Arjan B.'s Avatar
Look on www.porsche964.co.uk for details in gauge replacement if needed.
Old 11-04-2003, 12:53 PM
Roygarth
Roygarth's Avatar
Originally posted by John Boggiano
Piers,
er...I'm not sure how to respond to this..........oh what the hell........how can a dipstick not work?
Old 11-04-2003, 12:58 PM
johnfm
johnfm's Avatar
Piers
how hot are you getting the engine when you check level??
Old 11-04-2003, 01:04 PM
Roygarth
Roygarth's Avatar
Originally posted by johnfm
Piers
Very hot, 9 o'clock and slightly above.
Old 11-04-2003, 01:21 PM
John Boggiano
Lifetime Member
Piers,
You have definitely been spending too much time on the 993 board!
Old 11-04-2003, 01:23 PM
Riccardo
Riccardo's Avatar
Piers,
Leaking heads (or leaky engine in general for that matter, could be oil pipes etc) would not be shown by a leakdown test. An engine could be leaking oil but still be perfectly strong. My 964, when I sold it, was just like that.
If the engine leaks from the heads the only fix is a rebuild££. All air cooled 911 engines are prone to leaking and apparently it can develop over a short period of time.
Personally, I think you're just not reading it correcttly
Old 11-04-2003, 01:32 PM
johnfm
johnfm's Avatar
Piers
well 9 o'clock should be hot enough. I would suggest adding more oil until the gauge shows movement, but an overfill is a PITA. Sorry I can't offer any other help.
Old 11-04-2003, 01:44 PM
Richard H
Richard H's Avatar
I thought that if the gauge is pegged on full when ignition on it normally means the gauge is gone.
Richard.
Old 11-04-2003, 01:50 PM
Roygarth
Roygarth's Avatar
Piers
Thanks John, thats my worry as well ie an overfill. Don't 100% trust my reading of dipstick. Worried that if I keep adding the gauge may suddenly shoot to the top!
Quick Reply: Oil gauge not working??
