Need help identifying parts
Thanks, you are probably right, in fact they were in a bucket full of door stuff, butCan you please take a picture of the part you are referring to? I don't seem to find any screws like those in the PET diagrams for the doors or the door locks and I don't have the doors right now in my garage to check it, they are in the body shop.
Many thanks again.
Not a master here just took my fuel tank out a week or so ago and remembered they were long and had red paint. Will go out to garage and take picture of the part I referred to
top pic is side view in about the position piece is inside door fram 2nd pic same part different view in same realitive position of where it goes inside door 3 pic is screw hole for bottom and last pic is top screw hole in door above the latch
John many thanks again, not too sure about this one, according to the PET diagram, that part is supposed to be mounted using tapping screws 3,5x13 and the screw I have are 6,3x18, I don't think they fit there but I will check. Also I am not too sure why would they take that part out in order to paint the car in a different color, if I understood it correctly that part goes inside the door frame, doesn't it?
PET 7.3 Update 296/100 Have the rest of the updates, but everytime I start the program it says: "Error in last update, new update impossible! (PO)"
Have tried everything I could think of to fix it but run out of ideas...
What are you using?
What are you using?
Ok, now I know why. I am getting the parts for the VIN of my car (1990), yours is more modern, it uses a different newer shape part (same as 993 cars) I just checked it and the newer part appears if you choose 1991> 964 cars
my car is MY91I think the door parts are same as 90s I just googled door latch for 964 Porsche and door solenoid 964 Porsche
Sorry you are right I was looking at the wrong diagram, but still the PET says that part is held in place by a tapping screw 3,5x13 much smaller of what I have (6,3x18)
Part 15 in your diagram is door lock could solenoid cover the part I took picture of is the door latch cover both go inside door but I think they use same size mounting screws
Dude we are both correct 😎👍
