Cup pipe - one or two pieces
Hi,
is there any major pro or con to go for the one piece cup pipe instead of the two pieces?
And are there any major difference between the "cheap" ones and the "expensive" ones?
One piece:
Two pieces:
One piece:
Two pieces:
Ive got a 2 pice FVD one, no issues, but I imagine it is slightly easier to fit than the 1 piece
1 piece has the advantage of no potential leaks from the join, but nothing else AFAIK
Thanks, that's what I was thinking as well.
Now I need to understand if it does make sense to pay the premium price that, for instance, Superprint is asking against some "cheap" ebay JP?Dansk solutionsuper
http://www.supersprint.com/ww-it/por...240702.aspx#!/
http://www.ebay.it/itm/172376615364?...%3AMEBIDX%3AIT
Yep, it's just a pipe.... I had a buddy just cut out the primary muffler.
You could probably have it done for less than $100. (keeps the bend and attachment flanges stock)
https://rennlist.com/forums/964-forum/553583-primary-bypass-50-muffler-shop-cup-pipe.html
To mount it, do I need to remove the engine undertray?
Yes. I have a straight single pice 'cup' pipe. Have never had the untertray on either. End of the day, there is nothing special about one stright thru pipe over another - other than a nice easy installation and fit. It's a pipe, nothing else imho.
Yes you remove the under tray, and in my opinion no need to put it back (but keep it, you will maybe need it for the technical inspection).
I removed it more than 16 years ago and kept it in my garage.
Even for the official technical inspection I don't put it. They have never asked anything.
I have also the Cup tube during the inspection, but in my case it has the same color as the rest of the exhaust. So they don't see the difference
