964 Forum 1989-1994
Engine Carrier Reinforcement
Old Oct 27, 2016 | 08:30 PM
Goughary's Avatar
Goughary
That's interesting Bill- clearly Porsche knew it was an issue.
Old Oct 27, 2016 | 08:32 PM
JohnK964's Avatar
JohnK964
Mine MY 91 964 twisted at the end just loosening the motor mount bolts
Old Oct 27, 2016 | 09:19 PM
JasonAndreas's Avatar
JasonAndreas
Technical Guru
The removal of those nuts and the subsequent twisting of the carrier around the Z-axis has been the issue all along.
Old Oct 28, 2016 | 01:07 AM
911Jetta's Avatar
911Jetta
Bingo!
Old Oct 28, 2016 | 01:11 AM
JohnK964's Avatar
JohnK964
Default More info
I have to say my motor mount were shot and could have contributed to the twisting it seems like a very weak part
Old Oct 31, 2016 | 09:25 AM
964TT's Avatar
964TT
Originally Posted by Bill Verburg
Yes, here's a repaired one
Thanks, I'll get it sorted out. Solid info!
Old Dec 29, 2025 | 02:58 PM
SGOGT4's Avatar
SGOGT4
How difficult is the install for the reinforced carrier? Thinking of picking one up along with stiffer mounts and hoping I can do this myself in the garage without a huge amount of effort.
Old Dec 30, 2025 | 10:29 AM
JohnK964's Avatar
JohnK964
It isn’t too difficult There is a caveat though I don’t remember if the AC bracket needs to come off first. If it does the engine pulley needs to come off. If that is the case modify the AC brackets before you put it back on. There is a slight raised area on the bracket you can grind off so in the future you can get AC bracket off without pulling the pulley. Support that end of the engine. I always have luck by googling the specific problem. 99.9% of the time it will bring you back to this site. I promise someone else has already did what you want to do
Old Dec 31, 2025 | 11:34 AM
titleistaddict87's Avatar
titleistaddict87
For anyone interested I have a freshly powdered coated OEM engine carrier with the factory reinforcement for sale. PM me if interested, located in Bay Area.
