Does anyone here mounted an original (964 turbo) set Speedlines on their narrow 964?
Dimensions of a Speedline set
Front: 8J ET52
Rear: 10J ET61
Front should not be a big issue, but rear offset is another story??
-Do you need a spacer of 15mm to have some clearance on the metal oil line?
-Will the tire stick out of the body when using a spacer
- Is there an issue that the tire is very close to the exhaust on the right side
-Other say they just fit without any problem ...???
Hope someone here has this setup on his narrow 964 to clarify above
