Accumulator bleed nipple sheared off
I was doing a full flush on my c4 and my bleed nipple sheared off. Has anybody had this happen. I don't know what to do or where to start.
Nasty one best left to professionals to fix. I would imagine that they'd want to very carefully drill down the centre of the remaining stub, being careful not to damage the seat below then heat it up, then use a harden steel stud extractor to get it out or keep drilling until just the thread remains. The risk of course is that you do indeed damage the seat and I'd guess that there is only a very small amount that can be machined from the face to restore it. If the thread gets damaged, you could probably install a Time Sert or use an oversized nipple.
Best of luck though.
I would just replace the accumulator. Likelihood is it's dead anyway if it's old enough to have the bleed nipple rusted in there. And the shop cost for the repair of just the nipple is likely higher than just replacing the unit.
Thanks,
Drew
Word to the wise. Always bleed the accumulator slowly. Never just "open the bleeder" and let the fluid blow out fast, as it can damage the internal bladder...
