964 Rear Center Reflector Exposed
For those who wonder what the center reflector looks like under the lens here are some shots
I had one that was faded and cracked so I decided to try something different with it
Shot of reflector
Remove top seal, mine just carefully peeled off
You can either use a dremel to cut the lens off or heat and carefully peel it off the housing, I used the dremel with a cut off wheel
Center of housing
Left Side lights
Lens actually came off in one piece!!
I havent decided whats next , will post further when I do something with it
Shot of reflector
Center of housing
Left Side lights
interested in whats next as well...a well known weak point in 964's, along with the taillights...
