Anyone install Audette JW Speaker LED Headlights?
No one done these yet? Mine are on........but not correctly. Headlight ring WILL NOT snap over headlight bucket lip, so they aren't as secure as they should be. I think they look good, and they certainly light up well, but they are useless if they don't fit. By the way, these are the black-out version. Powder coated rings, inner housings, and black JW Speaker assemblies. Makes for a nice stealthy look.......................just wish I could get them on correctly!
JW Speaker-1 by HKnut, on Flickr
JW Speaker-2 by HKnut, on Flickr
JW Speaker-3 by HKnut, on Flickr
Ok gents...first start by taping (painters tape is fine)the area around the headlights...to prevent scratches. Then remove your whole assembly. Test fit the new headlight ...if they don't snap in as normal. Make a mark on the lip where they don't seem to go around. Then take small channel locks and gently(or slightly) bend the area on the lip inward(where the ring is having a hard time snapping in). Take your time doing this...it will snap in nice and tight...yes I installed the lights.
Can you tell me which model headlight you ordered, and the cost. Are they plug & play into the original wiring harness. How do they compare to stock headlights,
Here's Jonh's journey http://forums.pelicanparts.com/porsc...5-89-911s.html
His site http://www.audettecollection.com
Thanks Rey. So if I am understanding correctly, you are saying to take the lip and bend it back into the bucket ever so slightly to essentially reduce the outside diameter of the headlight bucket lip? Hope that works. I am excited about these lights. They are bright!
I'll take a shot against a wall after final fitment and alignment.
By the way, I think some lowering, black wheels, aero mirrors, and a rennline splitter will set this car off nicely! If I don't end up liking the blackout look, I have also considered going gold wheels with gold aero mirrors for some contrast. Baby steps first....
Beautiful car! I really like some of the changes, subtle without altering the car dramatically. The wheels look very nice silver.
Its too bad these LED headlight makers aren't making a single eyeball in the center of the lens that can produce High/Low beams or make it look similar to the 991 style with the light in the upper portion but a reflector light on the bottom half. In my opinion the top/bottom eye ball look is strange, then what are the little lights to the left and right side, some kind of DRL???
The Flat Six Illumination - Singer style is still the most classic looking design with todays technology.
