964 Forum 1989-1994
Rennline valve covers leaking`
Old Feb 27, 2017 | 02:45 PM
  #46
cobalt's Avatar
cobalt
Originally Posted by Goughary
Is that a 993 rear brake caliper? Or am I looking at a turbo?
Yes 993 with big blacks up front I decided to give it less of an aggressive look and swapped out the big reds for black. Also using the 968 M030 rear rotors. The turbo is a completely different trailing arm and the calipers have the raised pad and two raised lines above and below. They are generally the same as the 993 rears but require a 28mm vs a 24mm rear rotor. Also no spark plugs on the exhaust side of a turbo. Low compression and uses single plug. They got away with murder back then.
Old Feb 28, 2017 | 11:43 PM
  #47
jimq's Avatar
jimq
Burgled
I ended up buying aluminum covers. They were about $100 cheaper than the Rennline. Hopefully they dont leak. Should get them this weekend.
