Installing clear replacement for Bumperettes
#61
Peter, what more can be said....just absolutelySTUNNING!!!!!! I want your cup wheels on my car! The lowered stance really stands out too! WOW...I'm going to pull my pics quick! LOL!
--H
--H
#63
Lifetime Member
Lifetime Member
Just a thought - with people considering the legality of non-amber bulbs - you do realise that you can get 'silver' bulbs which are are amber when lit, don't you?
#64
Originally posted by John Boggiano
Just a thought - with people considering the legality of non-amber bulbs - you do realise that the 'silver' bulbs flash amber, don't you?
#65
http://www.performanceproducts.com/...;producttype=10 (The US replacement bulbs are 1157 twist mounts)
- I ordered mine and am awaiting delivery!
BTW, Great pics JB - your paint is beautiful - has it ever been resprayed? Oh! And on another note, do you have more info on the little hood/bonnet straightening task you set me (like a pic!)??? :-)
--H
#66
Well I'll be dam*d. I had no idea. I willbe ordering mine today.
Thanks.
Thanks.
#67
Lifetime Member
Lifetime Member
Here you go, Howard...
Front and rear lids each have a pair of these buffers which screw in and out on a coarse thread. Of course, you might then find you have to reposition the latch slightly. And then one thing leads to another and after you've split your head open on the latch 'hook' you wish you'd never bothered!
BTW, nearly all the paint is original, but I'm afraid is doesn't look quite as good as the pics make it seem.
#68
Thanks John! After examination it appears my hood lid is maybe 2mm higher on the right handside (seen in the picture) - I'll try this tonight and see what effect it has! Thanks for the picture - I thought you had originally meant the corners at the hinge!
BTW, my replacement handbrake sensor arrived, however I have ordered a replacement boot for my shifter and some new center console trim so once that all arrives I'll be revisiting the wobbly handbrake syndrome!
Cheers,
--Howard
Cheers,
--Howard
#69
I went to order the silver/orange bulbs. They had the larger bayonet mount but did not have the smaller waffle base side bulb. Any suggestions.
#70
--H
#71
The 1157 work on the turn signal, but the smaller side marker bulbs that fit into the rear lens are the waffle (can't access the website with the wireless at home So I don't know the number, I think it is like 113) mount. Similar in size to the side markers John shows mounted on the fenders. Johns car doesn't use them US models only I believe.
Your OK for the fronts.
#72
#73
