Full Circle - "New" 964
#31
Great ! Thanks !!
#32
Shake-down road trip. 500+ miles, rain, snow, mountains, and one slippery moment when the rear end came around at 50+ mph - good recovery, but could have been ugly if there were cars on the road. AWD's great, but summer tires don't work on snow @ 25 degrees.
Getting a brake warning light, which is temporarily fixed by filling up reservoir. Suspect a good bleed will fix the issue.
Little loose at speeds, and some bump-steer happening, but that could just be the frost-heaved roads.
Can't wait to get the Recaros mounted.
#33
New motor mounts; clear corners; full fluid bleed; etc; all courtesy dbfd garage
#34
Recaro test fitting - still waiting for 964-521-065-00 (seat belt buckle bracket) from Germany. Very nice "sport" type seats.
Also replaced the missing side-view mirror adjustment **** (911-613-082-00-01C, black rubber mushroom on drivers door panel); and burnt out side-marker light bulbs (999-631-032-90).
Rec'd, but not yet installed, Air Cleaner Clips (964-110-902-01) (2).
#35
Congrats again on the car.
These are Recaro Sportster CS Seats correct?
Did they come standard with Suede or is the material Alcantara?
Did Carbon Backing ever cross your mind?
#36
Correct. Recaro Sportster CS. One of the standard upholstery trims is black vinyl w/ black "Alcantera Suede". I don't think these seats come with carbon backing.
#37
^ motor mounts came from Pelican.
#42
Thx
#43
In a swift turn of events, the C4 has been sold to a dbfd affiliate (and hopefully new Rlister).
Recaros have also been sold and will ship soon to a Rlister in Chicago.
