964 Forum 1989-1994
Cam timing
Old Mar 31, 2016 | 09:15 AM
  #31
prschmn's Avatar
prschmn
Default cam housing
Am in interpreting correctly that the new cam housing is 2 MM
off from the old one?
Old Mar 31, 2016 | 10:51 AM
  #32
crg53's Avatar
crg53
The way i see it, the cam is held in place between part #2 and part #5 in the THIS diagram. The location of the plug in the cam tower should not affect cam location. The sprocket location is adjusted with the shims on top of part #5.
Old Mar 31, 2016 | 11:07 AM
  #33
prschmn's Avatar
prschmn
Default cam location
That's correct CRG. But the location of No 2 is determined buy the face of the cam carrier which is evidently 2MM "shorter" I.E. towards the flywheel end.
Odd problem for sure that it was machined so far off.
Old Mar 31, 2016 | 12:31 PM
  #34
crg53's Avatar
crg53
I am wondering if you have the cam chain sprocket on the right way around. On the left side, the sprocket should have the side with the undercut facing out, right side the flat side is facing out. Just a thought.
Old Mar 31, 2016 | 12:47 PM
  #35
prschmn's Avatar
prschmn
Default Why didnt I think of that
Yup-that would do it!
Old Mar 31, 2016 | 09:01 PM
  #36
vwomar's Avatar
vwomar
Default Thank you fellas!
That was it. I thought they cam off with both flat sides facing out. Flipped the left and it is dead on with two shims. Thanks again.
Old Mar 31, 2016 | 09:07 PM
  #37
vwomar's Avatar
vwomar
Default Thanks again
My relief far out weighs the embarrassment at this point
Old Mar 31, 2016 | 09:44 PM
  #38
crg53's Avatar
crg53
No worry, glad we could help. I quite often take pictures with my iPhone when I take stuff apart for the first time, has saved my bacon many a time.
Old Mar 31, 2016 | 10:10 PM
  #39
C4inLA's Avatar
C4inLA
+1 camera is my best friend on any P-Car detail work.... RL peeps come through again...
Old Mar 31, 2016 | 10:15 PM
  #40
FeralComprehension's Avatar
FeralComprehension
Yeah, nice save!
Old Apr 18, 2016 | 10:47 AM
  #41
ras62's Avatar
ras62
Ive also just had these seals and gaskets replaced, bank 1 was leaking but bank 2 had been off previously and was ok. There was also a leak from the crankshaft nose seal and the IMS O ring was replaced while everything was accessible.
The car feels much stronger and smoother than before. I measured 1.15mm of lift on bank 1 and 1.45mm on bank two prior to strip down although my Indy said not to trust those values as the chain tensioners will move differently when there is zero oil pressure i.e they advised to only use the proper tension tool when checking the timing to ensure accurate results. Not something I would have managed at home tbh as the distributor was a real pain to remove.
Old Aug 5, 2024 | 10:36 PM
  #42
L&M's Avatar
L&M
2nd Gear
aa
Old Aug 5, 2024 | 10:43 PM
  #43
L&M's Avatar
L&M
2nd Gear
Default 1988-1994 964 Timing Instructions
