Love it. And looking forward to it. The thread title says it all.
2 Attachment(s)
I got one of the Porsche Sport Classic radio's for it. We added an extra amp for it. Could not find a spot for a subwoofer that made any sense so going without. We also added the Escort built in radar detector and phase shifter (aka..laser jammer)
New speakers in the RS door cards.
Originally Posted by Mondrian
(Post 13658426)
Car is looking fab Marc, what have you got planned for Audio makeover?
Originally Posted by 02m2
(Post 13807715)
New speakers in the RS door cards. |
I have the window mount 9500i in my Cayenne GTS too and yes..has saved me countless times..."don't leave home without it". Went witht the integrated one on the 964 since the windshild is so close given the depth of the dash in the 964. The window stick on unit is right in your face and I didn't like it. Located the usb's there so not to get itn the way when shifting. Think we looked at a couple other spots but that one seemed like it would work oaky.
Originally Posted by cobalt
(Post 13807975)
Had one of those in my Cayenne GTS; worth its weight in gold. Never turn on the radio but I like the USB ports. I am assuming if you mount them on top they will interfere with the ash tray or do the cables interfere with shifting?
Silly question: did you manage to make your OMP hub to make the self-cancelling turn signals work? I have the same hub but the signals don't self-cancel with the new hub anymore.
From the pics, your hub looks like an OMP one and not Momo. Is that correct? |
No sure the brand but some private label that they used. Not Momo.
I suspected that they put the little plate that cancels the signal in backwards and had them pull it and check it. That is what had happened and now works properly.
Originally Posted by memo555
(Post 13808101)
closer
1 Attachment(s)
Well my 6 week paint job has turned into a year. Painter turns out has "issues" and so did my paint job. Rather than redoing it decided to clear wrap the entire car and then ceramic coat. Came out really nice. Side mirrors got resprayed and will arrive next week. A little bit more suspension work and should have it by next Friday.
Damn that looks good
Well guess not getting it back on Friday... just in from Joey at E-Motion who is setting up the suspension:
I have the car and working on it. It needed new tie rod boots up front and installed while doing tie rods. Also they didn't install bushings in the lower strut mount. JRZ probably didn't supply any. I had some made and installed them as well. Unfortunately they installed the front upper mounts backwards and didn't machine the towers. I will have to change and machine them in order to get proper camber To me all that means is post holidays .....ugahhhh |
Does look great. I love colors that contrast the black accents. really makes everything pop. Worth the wait. BTW what did you do to your tail lights to make them so dark? Was it a paint or film?
What color is that?? Is it a newer gray or a back dated color. Is it a metallic or flat color.
Thanks for feedback Merry Christmas to all |
4 Attachment(s)
We eneded up getting all new lenses for the car. I had them sprayed with tinted clear. We did it in seveal coats until I got the darkness I wanted. I apprently probably got the last set of front clears anb we tinted clear those as well. Probably all for the better since I have been reading people had a problem with the glue yellowing.
(Post 13827153)
1 Attachment(s)
It is slate grey non metallic. It is an original Porsche 356 color. There are multiple slate grey paint codes. This is the same color code as on Steve McQueens 930. It is color code 615
Originally Posted by Gus
(Post 13827210)
Caught a glimpse of your car on the Auto Kennel Face page.
Looks awesome in the sun! https://scontent.xx.fbcdn.net/v/t31....ff&oe=58EB6D4A |
LOL..that is actually at the shop doing the wrap and detail work. Auto Kennel uses them too.
Originally Posted by 911Jetta
(Post 13830903)
