Difficult to put into first
I know what you neam jevvy, but if a mecahnical or pin issue then you'd think the problem would be consistant at any temp - which it isn't... I would though check all movement around the pedals as in my case I did also end up cutting back some of that stuipid pedal carpet to get full pedal travel!
1) Jack up the rear of the car and remove the left side wheel. Don't forget your jack stands.
2) Open the trunk and clamp off the brake reservoir vent tube.
3) Attach your power bleeder to the brake reservoir cap and pressurize the power bleeder to 15 psi
4) Attach a hose and catch bottle to the slave cylinder bleed nipple
5) Open the bleed nipple with a 7mm wrench. Continue bleeding until all air stops and you see clean brake fluid.
6) Close the bleed nipple and detach the hose.
7) Depressurize the power bleeder and reassemble everything.
Total time should be approx 15-30 minutes depending on practice.
Note: I have the Motiv Power Bleeder which has a metal "European" adapter which perfectly on our cars. When I bleed, I put 1 qt of brake fluid into my power bleeder. When finished, I save an unused brake fluid and then rinse out the unit with denatured alcohol. Some others here will bleed with the power bleeder dry which can work too. The key is to use the power bleeder, instead of stepping on the clutch pedal.
While you have the car up in the air, that would be a good time to bleed the brakes too. The pressure bleeder will do both. You want to change your fluid every two years for street driving.
