Is this fine?
Is this fine?
I finally cured the horrible tire noise from the circa 2004 tires and am very happy with the conti extremecontact dw's. I also decided to put 5mm spacers on the rears.
Is that fine or is the lack of front spacers and issue? I have a 90 C4
Five is fine...spacing farther than 7mm on the stock studs is not good. People say up to 10mm on the stock studs, but I think they are crazy. If you go to 7mm switch to steel lug nuts since you have fewer threads. I wouldn't trust the alluminum nuts past 5mm of spacing. That said, I have a friend that has been driving on 7mm spacers in the rear with the alluminum nuts for years, and his wheels haven't fallen off yet....yet...
avatar is not a 964.
