964 Forum 1989-1994
Transmition oil
Old Nov 30, 2015 | 08:18 AM
kos11-12's Avatar
kos11-12
Hi guys , I am driving in Europe , I am using Mobile1 SHC with Redline LS additive , but I am not sure it's the best for smooth shift, Thinking changing to; Castrol 75w140 LS Or Motul 300 LS 75w90 Do you guys have any experience with those 3 ? I wonder witch one would be the best to protect and produce the smoother shift ,,, Thanks Konstantin
Old Nov 30, 2015 | 09:18 AM
Rocket Rob's Avatar
Rocket Rob
IHI KING!
I'm using Swepco 201 (80w90) in both of my cars. I had used the Mobil 1 SHC before but have easier access to the Swepco. Both seem to work well in our cars. No noticeable difference.
Old Nov 30, 2015 | 10:22 AM
crg53's Avatar
crg53
I went from Mobil 1 SHC 75w-90 to Motul 300 LS 75w-90 and didn't notice any real difference.
Old Nov 30, 2015 | 03:28 PM
Quadcammer's Avatar
Quadcammer
i like the redline 75w-90 NS
Old Nov 30, 2015 | 03:31 PM
LexVan's Avatar
LexVan
Mobil Delvac 75W90
Old Nov 30, 2015 | 04:48 PM
myflat6's Avatar
myflat6
+1 for Swepco
Old Nov 30, 2015 | 07:06 PM
justin-in-athens's Avatar
justin-in-athens
Originally Posted by LexVan
Mobil Delvac 75W90
While swepco 201 is not bad, the delvac 75/90 is the go to oil for the 964. The swepco is generally recommended for everything pre G50. Redline also makes a great 75/90wt.
Old Dec 1, 2015 | 12:22 AM
FeralComprehension's Avatar
FeralComprehension
Do a search on the PParts website as well as here- I've used Redline for years but Matt Monson of Guard Transmission categorically says not to use it, especially on the track.
I just drained the Redline out and put in the Delvac that LexVan mentioned- got it from Zoro for a pretty good deal. No miles yet.
Old Dec 1, 2015 | 12:41 AM
myflat6's Avatar
myflat6
I agree that is the word across Rennlist. However if you search the threads you will also read negative experiences with Redline and even a few for Delvac (mixed reviews for LSD). I have not come across a negative experience with Swepco in a G50. It has been flawless in both of my cars. Just my two cents
Old Dec 1, 2015 | 12:53 AM
Spyerx's Avatar
Spyerx
I run delvac in my gt3rs, 89 with lsd, 91 with lsd
The only downsides to delvac are no noise reducer additives for the lsd and it's a little balky when cold. But when warmed up its excellent. And in my rs running hard it shifts great, always.
Matt will suggest delvac and a couple others but his main advice is change it regularly. Especially with track use.
Old Dec 1, 2015 | 09:05 AM
kos11-12's Avatar
kos11-12
Hi guys
Thanks a lot for all the advises,
Is the Delvac the one called Synthetic ATF?
Will try to find it in France .
Old Dec 1, 2015 | 09:15 AM
LexVan's Avatar
LexVan
No.
Old Dec 1, 2015 | 09:23 AM
LexVan's Avatar
LexVan
ESSO Société Anonyme Française
Tour Manhattan
La Défense 2
5/6 Place de l'Iris
92400 Courbevoie
FRANCE
+33 (0)1.57.00.70.00
http://www.exxonmobil.com
Old Dec 1, 2015 | 03:38 PM
kos11-12's Avatar
kos11-12
ESSO Société Anonyme Française Tour Manhattan La Défense 2 5/6 Place de l'Iris 92400 Courbevoie FRANCE +33 (0)1.57.00.70.00 http://www.exxonmobil.com
Merci beaucoup
I try them
Old Dec 1, 2015 | 03:44 PM
Ken D's Avatar
Ken D
https://rennlist.com/forums/964-foru...s-magic-2.html
