964 Forum 1989-1994
Rear Wing Switch Housing Repair
Old Nov 19, 2015 | 12:20 PM
Super90's Avatar
Super90
Default Rear Wing Switch Housing Repair
Took a weekend to work on fixing the rear wing switch housing in the center console. The plastic tabs had broken off and it was rattling around loose in the console.
This is the object in question:
I fabbed up some tabs out of aluminum, drilled some holes in them to give the epoxy something to grab hold of and epoxied them in place. You can see the broken black plastic tab circled in the background.
Once those were in place, trimmed all a bit with the Dremel, then I slid the metal clips in place and installed in the car. All holding pretty well thus far.
Old Nov 19, 2015 | 12:50 PM
Earlydays's Avatar
Earlydays
Nice...
Old Nov 19, 2015 | 02:10 PM
DobermanDad's Avatar
DobermanDad
Doing your own thing in your own time, nothing better!
Old Nov 19, 2015 | 02:51 PM
swftiii's Avatar
swftiii
great solution, I'll have to remember that
Old Feb 19, 2016 | 01:13 PM
HiWind's Avatar
HiWind
nicely done! I did the same but with plastic and epoxy
used the clear plastic packaging from a box of screws .. like a splint
