Convert C 4 box to C2
#136
great update Jack! Not sure if you've owned a C2 before but I'm sure you've driven a few .. I guess the feel of the C2 is just a bit (tail happy) scary at first post C4
but as you say you can tone it down by softening the rear sway if its adjustable or stiffening the front etc.. and I guess you'll adjust to the feel quickly.
#137
I know just stiffening the front ARb would make the balance better but i think it's actually a problem of rear end grip so want to try and sort it from than angle rather than reducing grip at the front end by just stiffening that ARB..
#141
You've made so many changes Jack that rather than guess I would say its time for 1. Corner weighting 2. Geo by a reputable specialist. Corner weight is critical, it could be going down the road like a three legged stool!
#142
Hi Jack
Great video and great work. Admiring you'r will to go for a C2 setup on your C4. I would If I had the means and if it would pass MoT. Someone please correct me but no chance you pass swiss MoT with that setup/ or not get insurance issues.
I will observe your detailed analysis after a new C2 setup and will decide then what to do. Value is a bitch too, may be easier to sell and buy a C2 as long as I didn't spend too much money on the C4.
BTW of course your C2 setup will not behave nicely now, just setup your car to Cup or RS geometry/bars and it should run just fine. All the mods done to negate understeer will now induce too much oversteer. Not an engineer but seems pretty straightforward to me.
Keep up the good work & videos.
#145
Hi Jack
Swiss is not exactly a heaven for sports cars, England probably is , In UK you can build you own car, pass what its called the IVA and obtain a registration , I wish it could be the same in Europe
#146
Hi Jack
#147
Hi Jack.
I watched your videos with interest.
As you've already found out, you can't fit 964 C2 output flanges into a 964 C4 gearbox because of the diff. It uses different length output shafts.
The reason that you've broken the CV joint is simple, they're not strong enough. The 964 C4 is designed to spread the load through all four wheels, not just two. Porsche fitted larger CV joints and driveshafts to the 2WD version of the car for this reason. You've just found out what Porsche did.
There is good news though...
I am using a 964 C4 gearbox in a different project and as I'll be putting around 450bhp/450ftlbs through mine, I had to upgrade to 108mm CV joints (that's 964 C2 size).
The good news is that Porsche produced a 964 C4 Turbo-look and in the process, produced 108mm output flanges for the 964 C4 gearbox (yes... the odd length ones).
What's even better is that they're not silly money. I bought a pair direct from Porsche earlier this year for my gearbox.
PM me if you need some part numbers or text me on 07989 333437
Mike Ghia
Mike Ghia
