Standard 993 Carrera brakes (non big reds) on 964 C4...school me
As I'm sure everyone knows, Brembo makes a direct Bolt on kit (at least for a C2). Parking brake works as it should. Custom ordered from Brembo in yellow.
355 x 32 fronts
328 x 28 rears
Man are they unbelievable! Overkill for sure but eye candy too.
I've kept and refurbished 46k mile originals to stay with the car when I sell.
355 x 32 fronts
328 x 28 rears
if you need braking power, you may get it, but at the cost of significantly more added unsprung weight and the penalty in terms of feel and sense of 'lightness' lost as the car travels... not to mention $$$ involved
Tim Olsen at Olsen Motorsport recommended them and installed them so I went with his suggestion. Price was on par with Big Reds but Brembo kit was easy to order and install without modifications or bracket adaptors and such. My plan is to keep this car (and the original brakes) for a long time so I spent the dough. The setup is extremely well balanced and designed to work together front and rear. No regrets even though it was expensive.
Best brakes that I've had on any car ... feels fantastic along with the JRZ RS2's. Race worthy for sure although that's not my intention ... maybe 8/10ths track days a couple times a year.
Does anyone happen to have a p/n for the 25mm RS (largest of the 3) master cylinder?
EDIT: Found it ( 993 355 903 00 ) from an old Bill V post of course!
Has anyone installed one and know if it is bolt on to a 964 C2, from a physical size standpoint? And if I want to use the 25mm MC and have an RS Boost Ratio of 3.6, what are my options for brake boosters? Anything options outside of a part 993RS or 964RS?
Only issue I have encountered is with the prototype D90 (see my other thread about these wheels) where the front wheels need a 2mm spacer.
EDIT: Best info I could find so far: https://rennlist.com/forums/964-foru...e-upgrade.html
Price about same
Pad selection
Weight
Performance, modern new calipers and rotors
I also changed to 993 master and boosters and removed the proportion valve
going to bigger brakes seems to me to be a two edged sword in all cases
You need to drive mine. Too bad I can't get it up to the track today!
Which begs the question... what does it take to convert a C2 to a hydraulic setup?
here's the mechanical and hyd componenets of the eltro-hyd system, you' also need a different abs brain
I think if you're going to go to the effort of this you'd just get a tilton setup with dual masters... go full on, no assist :-)
I'm installing BBI wheel carriers on my 1990 C2, and converting from the small (964) to the medium (993) Brembos in the process. Is it possible to use 993TT rotors, or do I need the standard 993 rotors? Thanks in advance,
Note that you still want the 993 m/c too.
