964 Forum 1989-1994
Light weight flywheel
Old Sep 19, 2003 | 10:59 PM
Doug H's Avatar
Doug H
Default Light weight flywheel
Does this cause stalling. My car has stalled about for or five time (in a 1,000 miles), but the idle seems to drop low sometimes for a brief period of time. I just ordered a new K & N cone filter to see if that helps any.
Old Sep 20, 2003 | 07:16 AM
Adrian's Avatar
Adrian
Lead Rennlist
Technical Advisor
Lifetime Member
Simple answer, YES!!!! All the debates on this subject and the solutions are found on previous pages of this forum. The K&N filter will most likely make it worse not better. It certainly will not fix it.
Ciao,
Adrian
964C4
Old Sep 20, 2003 | 10:01 AM
Randall G.'s Avatar
Randall G.
Yes, yes, yes, it will cause stalling. The various band-aids may or may not work for you. The one solution that seems to be effective is Andial's semi-lightweight flywheel, which adds some mass back onto the RS LWF.
