Reading wiring diagrams
Hi guys,
Another quick question.
I am doing some re-wiring on my car. Does anyone of you guys know what the text box circled in red means on the drawing?
Is it a connection to another page or a reference to the fuse box,...? I can't seem to find the meaning of these text boxes.
Cheers,
Stig
Cheers,
Stig
Great! Another mistery solved. Do you also know what the other tex boxes mean? The '056' box for example? Is there an explanation for all these codes and boxes somewhere?
Cheers,
Stig
Cheers,
Stig
Same deal; column O row 56
Sometimes the letter that tells you the row is hard to read which can cause confusion but otherwise all the main pages work this way. The page with the central electric connections is slightly different.
To add to this:
Before you go off to column "O", row "8" , make a note of where the text box that has O8. Then go to column "O", row "8" and you should see that reference in a text box.
Here's more info on this post:
https://rennlist.com/forums/964-foru...ml#post3558295
