Engine tray removal debate
#46
If it comes down to you bottoming out, which could also indicate you have excessive suspension travel in some cases, the plastic little tray won't do anything. If that is one of your fears you should have some company fabricate a steel underpanel.
#47
Everyone seems to have their own view of what one should do with the under tray. safety, aerodynamics, and heat. Every bloke has their concern and opinion. Keeps the tires rolling. Of course then there is the foam on the tray that catches all the oil - seems that we could throw in fire hazard too.
I was more concerned about the heat, having read several post early on - think that was back in 2001 or 2002. Well, I wanted to keep the aero aspect of a clean bottom, but I wanted to make sure that the engine could exhaust the hot engine air and not have it trapped around the engine. So I decided to butcher the tray. Pulled out my trusty skill saw and cut the middle section out of the tray. The middle section, and restricted the air flow ( my thoughts ). - this left me a forward section and rear section of the tray. ( See Pictures ) This allowed me to keep the benefit of the forward portion of the tray for an aero dynamic flow and open the engine area up. Then cover the rear section of the tray under the muffler.
This all worked well while I had the two sections mounted on the car. Since then, have removed the rear section and vented the rear bumper to allow better air flow.
and cooling in the rear area ( this resulted from a discussion on Renn about the heat trapped behind the engine an the need to vent the rear of the car.)
I know some of ya'll will be aghast, but it works - is a good solution that can be done very easily, does not keep the car in stock condition - but you can always obtain another tray if you want -
#52
Everyone seems to have their own view of what one should do with the under tray...
So I decided to butcher the tray. Pulled out my trusty skill saw and cut the middle section out of the tray. The middle section, and restricted the air flow ( my thoughts ). - this left me a forward section and rear section of the tray. ( See Pictures ) This allowed me to keep the benefit of the forward portion of the tray for an aero dynamic flow and open the engine area up. Then cover the rear section of the tray under the muffler...
...is a good solution that can be done very easily...
Plus, it's an understandable middle ground. Makes sense.
Most importantly it adds something new to the discussion. THANK YOU!
