Godspeed Coilovers
#61
Buyer beware, you get what you pay for.
It's pretty sad when you can compress a Godspeed strut with one finger pressing down, but a Bilstein requires your entire body weight.
H&R really is the bench mark for entry level.
My .02
My .02
#62
I put the Godspeeds on a month or two ago but am just really back to driving the car now and no complaints. I'm not sure what the comment is about compression the strut with one finger as if anything they are too stiff like others have pointed out, you definitely want them on full soft which perhaps that is a good comment to make, you will end up with a much stiffer ride even on full soft so if you want a little more comfort and give in your ride then that may be the only issue I can think of. My disclaimer on that though is that I bounce between very 'soft' vehicles so when I get in the 964 everything about it seems very very stiff and tight...
I wouldn't shy away from them as I believe with these parts that we're simply not being charged the Porsche up charge.
#63
other than a minor incompatibility with one of the wiring clips on the front i've had no issues either--although mine is just a weekend car with the wife and kids.
i've set very (too) low and full soft. still need ride height adjust and alignment but am happy.
i would recommend this as an option for someone replacing their stock set-up on a street car.
#64
Technical Guru
Ive had mine on for 12 months now, and although not driven to extremes / all that often, I can agree with the previous 2 posts above. Made the mistake of trying a few turns from soft, the UK roads did their best - and within a mile or so, i went back to full soft, and its been there ever since.
I too had to get the dremel out to fit one of the clips in properly - but it was a minor issue, well worth it.
Just my 2p's.
Just my 2p's.
#66
Biggest issue we've had w these is the lock ring continually coming loose. Anyone else have this issue?
Would be nice to get a second lock ring and lock them down tight. Or add a set screw to the lock ring so it can't move. So far- still a fan at the price, not a fan over-all. I'd spend a few hundred more to get something better. Or save a bit and spend for even better.
#70
All of the pictures I've posted of my car are with these coil-overs installed.
![Name: AKtd5gBl.jpg
Size: 60.2 KB](https://rennlist.com/forums/attachments/964-forum/1353581d1683259891-godspeed-coilovers-aktd5gbl.jpg)
![Name: GcF9Jo8l.jpg
Size: 66.5 KB](https://rennlist.com/forums/attachments/964-forum/1353582d1683259891-godspeed-coilovers-gcf9jo8l.jpg)
I have to say that after a year of driving on these, I'm very pleased. For on the street, they're great. Feel very similar to how the H&R's and KW's I've had in the past (on different cars though).
One thing I've been meaning to do is raise the fronts up a tad. Really have them too low and it rubs when I hit a bump or corner hard.
Goughary, I haven't noticed the lock ring coming loose on mine. Once the top spring is pre-tentioned, the ring has stayed in place for me.
I do wish the adjustment was more traditional so that rather than having to detach the bottom bolt to spin the whole thing down or up you used the spring perch to lower or raise it. But you get used to it.
Has anyone experienced any corrosion? Mine seem to be doing well for going through one winter.
#71
These are like the BC Racing for the NSX.
I'd pick these vs. the KW V1 but not vs. a set of Ohlins DFV...
#72
need to wake up the only good thread about godspeed coilovers.
Any updates on using godspeed after a while ? any sign of rust as people stated ?
really thinking of pulling the trigger on these, for $840 they are not easy to ignore !
#73
I recently did a brake job on my car and inspected the suspension while I was there. I did have corrosion on the threads but the coils and body were all in great shape. I took a soft wire brush to the threads and they cleaned up nicely.
I'd love to find a coating to put on them to prevent this from happening, but it's been over a year and if that's the worst then I'm happy with them.
Sorry, didn't take any pictures but I'll take some this next weekend when I put my new wheels on.
#74
Glad to hear they are still holding together. guess its surface rust then.
What about handling compared to other coilovers ? not looking for something aggressive.
Car will be 80% for the street and 20% track time, not a daily driver.
Really considering them!
#75
Bumping this thread again, since it has been another year. Any more reviews and updates?
In my opinion, you get what you pay for. Cash out for KWs and they'll last the life of the car; I wouldn't expect these Godspeeds to last more than a couple of season with occasional track days.
But for the price, with adjustable dampening and camber plates, I wouldn't mind buying these a couple times if they're at least holding up for the short term...
