Engine Stall
I have periodically had the no start problem when the engine was warm, however, today, my engine stalled twice while driving. This morning, it happened while at a light, when the engine, without warning, just cut out. There was no sputtering or caughing. It just stopped as if I turned off the ignition. This afternoon, I was driving at about 60 klm/hour, when the same thing happened. All the dash lights came on and the motor was dead. I waited 30 seconds and it fired up as if nothing was wrong. This problem has the potential to be dangerous.
Any thoughts on cause/resolve?
Lead Rennlist
Technical Advisor
Lifetime Member
Lead Rennlist
Technical Advisor
Lifetime Member
Dear Syd,
Ignition switch. Check your keyring. If it is too heavy it can move a worn switch.
Ciao,
Adrian
964C4
Ciao,
Adrian
964C4
