964 Forum 1989-1994
wheel studs
Old Jun 10, 2015 | 01:03 AM
mooty's Avatar
mooty
GT3 player par excellence
Default wheel studs
are they screwed into hub from the front or the rear? in another word, do i need to remove the hub in order to install/remove wheel studs?
TIA
Old Jun 10, 2015 | 06:59 AM
jlmartin94's Avatar
jlmartin94
Hi,
A friend of mine changed her studs for longer ones .
they are not screwed but pressed from behind the hub ...
can be done whitout removing the hub
Old Jun 10, 2015 | 07:16 AM
suzaan's Avatar
suzaan
Possible? Yes, if you have a very heavy duty c-clamp, tie rod end remover, or on-car stud press (last two might be available at auto parts stores that loan/rent tools). Do a search on "wheel stud press" for ideas.
Old Jun 10, 2015 | 07:48 AM
Jason @ Paragon Products's Avatar
If you click on the picture you can better see the splines that grab into the aluminum in the hub. Press out the old and press in the new.
http://www.paragon-products.com/Whee...331.671.00.htm
Your Porsche Parts Superstore
Parts | Tech-Session | Facebook | Youtube
Jason Burkett
Paragon Products - Porsche Parts & Accessories*- 800.200.9366
Tech Session - Porsche Tech & Info*- 361.289.8834
jason@paragon-products.com
Old Jun 10, 2015 | 08:50 AM
BHCfarkas's Avatar
BHCfarkas
TIA
Nope, they're pressed in. Simply punch them out, and then use an old lug nut with washer against the hub and tighten to seat the new studs completely. No special tools necessary, that's just hogwash.
Old Jun 10, 2015 | 09:25 AM
davidwilson11's Avatar
davidwilson11
what size are standard studs?
Old Jun 10, 2015 | 09:50 AM
HalV's Avatar
HalV
Stock Length is 45mm. Thread pattern is 14 x 1.5.
Old Jun 10, 2015 | 10:00 AM
crg53's Avatar
crg53
Whatever you do, do NOT hammer them out. You should never hammer on anything that has a bearing attached to it.
Old Jun 10, 2015 | 10:02 AM
Function-First's Avatar
Function-First
Basic Sponsor
Take care to not damage the wheel bearings trying to hammer the studs out.
(ie. think twice before taking that sledgehammer to it)
Comprehensive Shifting Solutions for your Porsche.
Old Jun 10, 2015 | 12:17 PM
LimmetED's Avatar
LimmetED
this is what i used when i replaced my 45s to 66s(hub on) and then i did like BHCfarkas "and then use an old lug nut with washer against the hub and tighten to seat the new studs completely"
Old Jun 10, 2015 | 03:28 PM
Steve Weiner-Rennsport Systems's Avatar
RL Technical Advisor
TIA
John,....need longer ones?
Old Jun 12, 2015 | 09:54 AM
cobalt's Avatar
cobalt
Another concern is be careful when installing the new ones. Try to align the splines with the splines on the hub. I have seen people screw this up and ruin the splines once that happens you can find yourself with a stud spinning and the hub ruined. Loads of fun trying to remove a wheel once this happens.
Old Jun 12, 2015 | 11:01 AM
HalV's Avatar
HalV
^+1...another thing that can happen is that aftermarket studs often have larger splines to keep them from spinning. That's great until you want to go back to your stock studs! Anther thing you can do to keep your studs from spinning is to use Green Locktite or a little JB Weld. If you're already at the spinning part you may be able to tack weld the back of the studs.
