Gear change problems - clutch or box?
Mine ended up being another broken pin. Too bad I didn't have time to look for myself, could have a saved a bit of $$. But the replaced a few other "little" things for me.
Hope you get yours worked out.
Lesson learned, I think I'll order a spare pin and keep it with my extra relay switch!
I thought mine was the roll pin, but alas it turned out to be the clutch master cyl. If you are doing the roll pin check the fluid at the master. Mine was horrible, a thick grease like graphite coloured mess, yet the slave looked fine when bled. My master had actually broken the retaining cup inside the piston. Replacing it and 1 litre of fluid, hey presto I now have a great clutch again.
K
K
1 Post
![](https://cimg2.ibsrv.net/gimg/rennlist.com-vbulletin/448x336/sheared_roll_pin_e0cef9ee582f7cb8e7ba2fae08598d5b95f65d4f.jpg)
Dr Mitch, glad your car is back on the road again and while you probably would have saved some money by replacing it yourself, I guess you should be glad it was nothing more serious.
Hey warmfuzzies, how do you check the fluid at the master cylinder? Is it difficult?
My clutch roll pin looked like the picture below when I finally managed to get it out, so I'm hoping a new one will solve my problems. I do have a feeling that my gear changing problems are caused by more serious (hydraulic) issues, and will receive an offer from my local workshop on replacement of slave and master cylinder, as well as complete clutch replament tomorrow.
Took the Master cyl to bits, simple job. pull out plunger arm , and out pops the piston. Just be careful on reassembly not to tear the seals.
K
1 Post
I finally got thet roll pin this saturday, spent the sunday replacing the pin and installing the pedal assembly again and the clutch now feels good. I did experience some squeeking from what I believe to be the slave cylinder during the first drive after install, but that has now gone away, and all feels normal.
Considering the amount of $$$ saved from not sending the car directly to a Porsche workshop, I'm pretty stoked. This was my first DIY ever (granted a pretty small one) and it feels good
![Cool](https://rennlist.com/forums/images/smilies/cool.gif)
I'm having the valves and rocker arms adjusted (2000 km post rebuild adjustment) done in a couple of weeks, and I'll have the workshop inspect the clutch then. Until then I need to add roughly 500 km on the car, so it's gonna be some busy evenings forward. Fortunately spring has finally come to Norway, so it's all good
I want to thank you all for tips and insight! Highly appreciated!
Good to know you fixed it all. There's a lot of satisfaction and learning from having a go yourself. Plus, your not up against the garage hourly rate clock having to rush the job. Nice one...
Technical Guru
What size is the pin? Can someone measure it? I'll stop at Ace and pick one up before I knock the old one out. Or I guess I can stop at the dealer for a few cents more.
