Rear center reflector top seal
Hi guys and gals,
It's been a LONG time since I've posted here, but I still have my 90 C2 cab with 107K miles and running strong.
I'm getting ready to replace the rear center reflector top seal. What adhesive is recommended for the installation? I've seen the 3M Super Weatherstrip adhesive, but it looks like it is best suited for bonding rubber to metal, not rubber to plastic.
Thanks in advance for suggestions,
Jeremy
Jeremy
Hi Temp silicone.
The seal I got from dealer was peel and stick foam...just like i could have obtained at local hardware store and cut myself...i will know better next time..
Burgled
Things are good. How did you end up going from Jacksonville to RI? Must be a big change!
The suspension we put on still on the car? Mine hasnt fallen off yet
I occasionally post the picture I took of your rear shock connection when people ask the difference between the old and newer style mounting.
