New clutch kit....should I go RS flywheel
I guys, going for a clutch replacement in my c2, will a change to the RS flywheel be a good upgrade? I use the car on weekends for road spirited driving, no track, so what would I feel to make this money worth?
RL Technical Advisor
Hi,
Unless this is a daily driver used in rush hour traffic, I would install the RS LWF kit. The difference in throttle response between the 38lb DM and the RS 13lb one is quite noticeable.
Just make sure your engine is in excellent tune and clean out that Idle Stabilizer Valve very thoroughly.
I did a clutch in my car and used old DMF. Prob only has 2k miles on clutch. I Almost want to abuse it so I can go the LWF route. Regret not doing it. Next time for sure.
LWFW + started ring
Dual mass everything:
Lightweight everything (ignore tube)
Still significant, but NOT AS MUCH.
Also, replacing clutch on DMFW is much less expensive than doing whole LWF conversion. According to Sachs DMFW can go over 2 clutches.
Also, DMFW, is not plain hunk of metal - it is pretty nifty device
http://www.understeer.com/pdf/dualmass.pdf
good reading there
