Engine wont tick over - stalls ??
My 964C2 has a warmed over engine with Cup cams and remap , lightweight flywheel , de-cat exhaust . Recentlly serviced , new plugs and tappets set.
On cold start up , the car always fired up at say 2500 rpm then dropped right back say under 1000 rpm , then picked up and oscillated 1500 to 700 , steadying out after a couple of minutes to a 1100-800 'hunt'.
In recent months it has occasionally stalled on that first drop back.
Starting from warm it never stalled.
I took it out on a recent trackday , had to keep some revs on whenever I had to stop at traffic lights etc when cold on the journey out , no problems at first on track , then it stalled when reversing back into pit garage. After that it seemed susceptible to stalling when warm on the return journey.
Checking it out a few days later after a cold start it would not keep running without I gave it some throttle ,for 5 minutes or so to move oil temp needle off stop but as soon as had to take foot off throttle -to apply brakes- it stalled .
What are the likely causes ??
However - good news - boxsey
popped round to have a look and suggested disconnecting the Hall sensor at the distributor.....tried this and it fired up and then settled down into a lumpy idle ( normal ) without intervention , and drove round the block without stalling , so at least will be able to get it to Unit11 in confidence.
Rob
