Fog and Defrost switch bulbs
Anyone know what type or bulbs are in the Defrost and Fog switches?
I need to replace mine.
Also, do the cap just pop off?
Don't know the bulb size. My bulbs were just loose not burned out. Pushing them into the socket fixed my problem.
The Old design is like a drinking cup upside down placed into the pull ****--bottom of the cup has the insignia. When you push back the rubber lip and tried to pull out the fog light or defroster plastic insignia You may break the "cup" .
The new design is a disc which is easy to remove and replace into the pull ****. I have an extra fog light disk if you want it.
Fog and defrost switch bulb is Sylvania 2721.
90063113290
https://www.pelicanparts.com/More_In...631-132-90-OEM
90063113290
