964 Forum 1989-1994
I'm a Dork! Clutch slave bleed...
Old 03-05-2015, 10:02 PM
C4inLA
C4inLA's Avatar
Okay, I give.... Please recap 13pt WET bleed method with motive? Do you push everything from reservoir or some that way and reverse clutch slave?
Thanks!
Old 03-06-2015, 12:35 AM
YaHoo!
YaHoo!'s Avatar
Yes. 13 pt wet all through reservoir.
For me its way easier to rinse and pump a little denatured alcohol through the bleeder to clean the motive than the effort required for the dry alternative.
Old 03-06-2015, 12:27 PM
C4inLA
C4inLA's Avatar
I am gonna do it.....can I get a few of you chaps to share your brake fluid of choice?
I use Ate 200 I think.... Always like to see where the Vets are on this topic?
Thanks!
Old 03-06-2015, 12:52 PM
KaiB
KaiB's Avatar
I also don't understand the 13pt deal...help?
Yes, wet is the way to go. Two pints in the bleeder for me, and everything gets taken care of every ten hours.
Old 03-07-2015, 02:52 PM
C4inLA
C4inLA's Avatar
Do a search on C4 brake bleed. C4 AWD has two locks (PDAS) that need bleeding in addition to a C2 11 pt bleed....
Old 03-07-2015, 04:36 PM
KaiB
KaiB's Avatar
I only have ten fingers upon which to count, and generally only need 9 to bleed my car out.
Eight caliper nipples and the clutch.
Maybe THAT's why I'm so slow on the track, I dunno.
Where could the other two be for an eleven point bleed?
Old 03-07-2015, 06:39 PM
YaHoo!
YaHoo!'s Avatar
D'oh! KaiB apparently you are quicker than me; I have only 9 nipples (not 13 as stated above).
Old 03-07-2015, 09:38 PM
C4inLA
C4inLA's Avatar
You guys were warned and should beware of any thread with "Dork" in title.....
I was speaking of hydraulics bleeding as whole ... 13pts bleed.. I did creative math and subtracted 2 locks to arrive at C2 of which I do not own
How many bleedable nipples in a C2 bonnet area or as I call it trunk?
Are you saying C2 is 10pt bleed?
Old 03-07-2015, 10:16 PM
YaHoo!
YaHoo!'s Avatar
C2=9. 2/caliper X 4 calipers + 1 for the slave. No bleed nipples on a C2 ABS which is in the frunk.
Old 03-07-2015, 10:31 PM
C4inLA
C4inLA's Avatar
Pressure Resevoir? Master cylinder? Maybe that's where I read 11? Not sure, I dunno
Quick Reply: I'm a Dork! Clutch slave bleed...
