Top end rebuild questions for a 90
#31
My '90 is wet on cylinder 1 with occasional drip. At this point, I will keep driving it and keep cardboard under it for the drips. Did order the video to hopefully tackle part/most of the rebuild when the time comes.
#34
I worked with Steve when i rebuild my 91, it turn out great, no leaks and runs great
i used 993 studs, heads where grooved for gaskets and rebuilt
I ended up doing a completed rebuild with sleeves and pistons
Viton gaskets and al new bearings
(Steve has invaluable advise)
i have this documented here under Enso
Glenn
Glenn
#35
Glenn
Glenn
#37
Just figured I'd post some pics of last nights tear down for you, Ed ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
I can confirm that this was not just a case of "It leaves a few drips on the garage floor". That was corrected with the previous run of maintenance. If you drove behind Ed while his 964 was under heavy throttle, your car would be coated in a lovely mist of BradPenn. It was basically a SpyHunter oil slick spray function.
Hard to tell in these pics but 5 of the 6 were obviously leaking between jug and head. #2 and 3 were the worse.
![](https://farm9.staticflickr.com/8619/16390342579_a84d3a9499_c.jpg)
![](https://farm8.staticflickr.com/7387/16390351649_905e9a3ddf_c.jpg)
![](https://farm9.staticflickr.com/8607/15954098214_9072002582_c.jpg)
Getting ready to pack these up and send em out. If you look at the portion of the heads where it mates to the jug surface, you can see where the top of the cylinder surface is clean and the bottom of the cylinder mating surface clearly shows where the bottom of the joint was blowing out oil. Quite a bit of it on 5 cylinders. Heaviest on #2 and 3.
![](https://farm8.staticflickr.com/7336/16576661235_6e6c9e4460_c.jpg)
Those air duct covers were FILLED with oil and grime.
![](https://farm8.staticflickr.com/7420/15954094514_afaebd5785_c.jpg)
#38
Also note the exhaust valve that was running hot. Most likely a worn guide. Did I tighten the lash too much on the last valve adjustment? No biggie it will be rectified.
#39
apologies for bumping an old thread .. can you explain with reference to the pics how you deduced this - are you referring to the light grey color?
#40
