EVO HighFlow FRESH Air Intake System - anyone got one?
Ok, just managed to get mine done today. First, this is how it was before i started:
I made this bracket (thanks JPAR for the idea) from an old bit of flexible metal I found. I have put it next to the ruler so you can see the dimensions. Wasn't too difficult to make up and as it was flexible steel, it was a little forgiving
And here it is on the ATM. Note that the adaptor I purchased the holes didn't quite line up, so had to jig them around a little. They provide a horrible plastic gasket with the adaptor, so I did not use that - I just reused the original paper one.
I also mounted the air cylinder a little different to JPAR, as the piece of metal i was using wasn't that wide, I could not drill a hole big enough for the top part to clip through, nor did I want to screw into it. So, I dremelled off the end of it, so it was flat, then pushed and glued a brass nut in the hole, then screwed it from the outside.
And here is the finished product with K&N filter.
For documentation purposes, here are some photos of the EVOMS Intake system with their L bracket/vacuum tank installed.
