964 Forum 1989-1994
Replacing front and rear shocks
Old 11-24-2014, 01:19 PM
John McM
John McM's Avatar
You need a special tool to hold the inner spindle still while undoing the top nut. I had to refurb two RUF Bilstein front struts ( rebranded HD) on my 964 because some muppet had tried to hold the body of the shock instead, probably with vice grips and had scratched it badly. The body goes through the seal when in use so would have eventually ruined the seals. I understand it can be done with an impact wrench. I don't have one, hence the need for the special tool.
Old 11-24-2014, 01:59 PM
Jason @ Paragon Products
Jason @ Paragon Products's Avatar
Originally Posted by Gregt909
Hi all,
I just got a new to me 92 Carrara 2 and I want to replace all 4 shocks. I believe the front are struts? Any advice on what type to use how to replace? I'm planning on keeping the stock ride height. It's just a weekend driver, not a track car......
Koni has several options...I'd suggest the FSD
http://www.paragon-products.com/Sear...x=0&Search.y=0
Your Porsche Parts Superstore
Parts | Tech-Session | Facebook | Youtube
Jason Burkett
Paragon Products - Porsche Parts & Accessories*- 800.200.9366
Tech Session - Porsche Tech & Info*- 361.289.8834
jason@paragon-products.com
Old 12-22-2014, 02:53 PM
Gregt909
Gregt909's Avatar
Thumbs up
Just bought all 4 Bilstein HD's from Shock Warehouse. $940 for the set. Seemed to be a pretty good price compared to others
Old 12-22-2014, 03:45 PM
abarthguy
abarthguy's Avatar
The 'special tool' for the front shocks is a $6 oxygen sensor socket from Harbour Freight.......
Old 01-15-2015, 12:14 PM
GoKart
GoKart's Avatar
Did all of you replace your strut mounts as well? Or not needed?
Old 01-15-2015, 06:03 PM
Richard Curtis
Richard Curtis's Avatar
Bilstein HDs for me, too. The rear bottom bolts were VERY tough to get off (I think they had been red Loctited), but otherwise a straightforward DIY. I did not need a spring compressor, and I didn't replace the shock mounts. You will need an alignment afterwards.
Quick Reply: Replacing front and rear shocks
