rear undertray fixings
Agreed 100%. I made the mistake of using oem clips once. After a year they needed to be drilled out . Most hardware stores sell speednuts, and if you can't find them locally, buy a box from McMaster carr. Use stainless bolts with them if you are in the north where they use salt in the winter and coat the speednuts with a thick non-synthetic grease and the steel won't rust. Or will rust less...
Are you looking for hardware or the extension bars that the hardware mounts to.
