Air Deflectors on control arms
see pictures below. the black plastic guard on each control arm
When I removed the arms to install the cw bushings. I managed to broke the bolts that were holding the reflectors. Those bolts were seized good after all these years.
I haven't been able to remove the broken bolts and have been driving the car without those reflectors.
What are the function of those pieces? Are they there to guard the arms from debris? Are they directing air to brake? I found the term air deflector from the forum...
Is it okay to continue driving the car without them? I do plan on taking the broken bolts out in the future.
![](https://forums.pelicanparts.com/uploads20/frontsusp11334084035.jpg)
Those are in fact brake ducts. They deflect the air from under the car into/through the front brakes and wheel outlets. On later cars particularly cup race cars they are pretty important in the performance of the brakes. For street probably not a huge issue but for any track applications I would make sure they are in place.
oh. no wonder my brake performance suffered so much from traffic light to traffic light
j/k
thanks or clarifying. I do plan on putting them back. Only problem is I can't get those seized bolts out. It's really the shanks of the bolts that are likely fused together with the control arms.
I've driven across Europe with no deflectors
I wanted to stop in Switzerland but over shot my braking point and ended up in NW France
You will have zero problems driving without them
Formerly turbotwoshoes
I had purchased to extra arms to refurbish before I redid y suspension. I had the same problem with sheared and frozen bolts. The previous owner (did not tell me) had tried to drill out two of the bolts and had left the broken bits in place. I bought some quality cobalt bits in several small sizes and drilled what I could out. Even with heat, they would not budge until I had drilled nearly completely through. A good drill press, bits and a couple or three hours should get it done.
Find an 'EDM' ( I believe) shop near you. It will remove the broken bolt without harming the arm.
Good thanks, drove my car in torrential rain last weekend, shouldn't have removed the sunroof drain tubes
so carbon sunroof infill panel is my next job.
As I'm working a 1000 miles away from my car I'm keeping myself busy thinking up ways to save unsprung weight.
![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
