Does anyone have pics of worn and okay trans mount inserts. I have a feeling mine are shot but had a hard time getting a good look last time I was under there.
Thanks in advance,
Thanks in advance,
Just to clarify, you're referring to the OEM trans mount bushing, correct?
You'll want to pull back the rubber bumpers on either side of the mount to check and make sure the OEM bushing is not cracked or torn. If it's already torn, you'll need to replace the bushing before installing the inserts. If not torn, the inserts can be implemented to fortify the bushing, returning it to its original geometry and preventing further wear.
Originally Posted by Mr.Alex
How much would these increase NVH?
Based on customer feedback, the AWD inserts will add little to zero perceivable NVH. For 2WD applications, you'll want to stick with the street version if NVH is a concern.
You can check the 993 forum for some more reviews, as that chassis utilizes the same transmission mount.
