Well that's a little worrying... decision time!
Hi chaps
Dutchcrunch's idea would be a lovely solution if it turned out to be right.
I dug out a shot of my distributor shims on the shaft. I guess if one of the smaller shims (or the gear itself) ground through the larger one... possibly?
I'd so like it to be true. Does this help:
Hi chaps
So we've looked into the possibility of the mystery piece of metal being part of a distributor shim washer and my specialist and I are in agreement that it is unlikely (sadly) due to the fact that the gearing at the end of the distributer would have to have broken off, which in turn would likely stop the engine running, as shown here:
There is always the option of just ignoring things, drive the car and see how we go but I don't think I'm brave enough for that. Especially as the metal was an almost perfect fit to the IMS bearing. If we left it to wear away further we could be looking at damage to the crank and crank casing and significantly increase the repair bill. On that basis the only way to see what is going on is to open up the engine and in which case we may as well rebuild.
It was worth consideration though, so thank you guys
fod
when I say the lower bearing seized , it does not mean the distributor gear will fail, as the shaft will turn within the inner race, but the shims will become a wearing surface. if the bearing is good, the gear washers and distributor shaft will turn as one piece. just looking at the lower gear part will tell you nothing.
lets say that that bearing was seized, and a washer did fail to the point it fell apart, you would not know until you took the gear end off and inspected the shims and bearings. perhaps i'm not the best at technical writing but i'm sure someone else can explain it better.
