Best brakes for 17" wheels...Or should I go 18"?
I went extreme and run the 964 front calipers in the rear with RS rotors (yes I know) and use an adjustable Tilton bias valve.
A stock 964RSA, 1.734 below 55bar line pressure and 3.210 above, these cars can easily get better and get the rear to do more work by just removing the p/v
a stock 964RS, 1.713 below 55bar line pressure and 3.171 above, again, remove the p/v as was done on the 964 Cups.
993tt/RS front and rear on a 964, 1.659 below 55bar line pressure and 3.071 above, again removing the p/v is beneficial
993 front and rear on a 964, 1.604 below 55bar line pressure and 2.970 above, again removing the p/v is beneficial
if you don't need a parking brake 993RS on a 964, 1.426 below 55bar 2.640 above, again removing the p/v is beneficial
the lower the ratio the more beneficial a low stiff suspension w/ an effective lsd is
Just FYI as another data point...I get no brake fade with my stock brakes, fresh ATE Super Blue (now Gold), Kumho R compounds on Cup 1's, Hawk HT-10 pads which I love for their great stopping power with a more progressive feel than the Pagid Orange / Black pads that I used to use. The Pagids also used to leave excess pad material on my rotors causing bad brake judder at times. 15-30 minute DE sessions at some hard braking tracks (Sebring, Road Atlanta). I don't track my 964 much since getting a Miata nearly 2 years ago. I run the same fluid and pads on the Miata too. YMMV.
Good luck!
Good luck!
Yes, in general the stock 964 brakes with fresh ATE fluid and good dedicated track pads (Performance Friction has several models) should hold up well at most DE-type track events under normal circumstances. The slight exception is if you have the older/smaller 2-pot rear brake calipers, which may not have enough pad material to dissipate the heat under extreme track conditions. What year is your 964?
I don't know anything about the Brembo brakes that you refer to; however, I would think that the most logical and straightforward brake upgrade would be one of the proper combinations that include the 993TT fronts. This requires 993 master cylinder and booster, and some other modifications; but is otherwise a mostly bolt-on option. Balance is important (as Bill V shows), but the braking and heat capacity is beyond what most mortals could ever need.
Good luck!
Good luck!
Bill, I know you're kind of he brakes expert on here
What would be your recommendation for my application?
Stick with my set up and improve pads and fluid?
Bid reds?
Brembo?
Thanks!
Bid reds?
Brembo?
Thanks!
As has been mentioned ATE 200(aka blue) is a fine street b/f but is less than optimal for stressed track applications, If you have a car w/ really outstanding brakes that aren't stressed under track conditions it would be fine too but 964 stock brakes are certainly stressed. I'd first try a more track oriented fluid, SRF is best but Endless RF650, Motul RBF600 and others are not far behind, Here's a great interactive b/f compendium, Brake fluid comparison
Either 964RS or 993tt w/ 993 rear would probably be more than sufficient for your purposes, the bias could be more rear on either of these so, remove the p/v to help that. This sort of setup should be 1/2 the cost of a Brembo set.
I'd also advise against using holey rotors, use slotted for much better rotor life.
You are correct Kai. It was definitely the orange pads I was running up front. I should not have implicated the black pads in my statement. I used black pads on the rears without issue but when I started using the HT-10s, I just liked the feel so much, I quit experimenting with the Pagids.
Pagid yellow RS29 or black RS14 on the other hand are great products, alternatives to these would be PFC 01 or 11
Bill, I've run the RS29s exclusively for quite some time now and am very happy with them.
How do the PFCs differ in terms of feel, grip, modulation and longevity...and price; might want to try, a lot of guys seem to like them.
Reviving this thread.
I've decided to keep my set up and "upgrade" it
Changing pads and fluids to your recommendation - thanks guys.
Should I also change brake lines and discs?
If yes (not sure mine ever got replaced...) what should i go for?
Thanks!
Thanks!
