Flywheel ring gear always steel?
Are LWF ring gears steel or aluminum? I can't imagine a aluminum ring gear would last very long. Trying to figure out what the coupe has for a flywheel. A magnet is sticking to ring gear from the window on the side. Car sure feels like it has a LWF.
Thanks Rob. Means I am on the right track thinking this is a LWF. I drove your cab and it seemed the same as my car. That had a DMF back in 2012 right?
Technical Guru
