964 Forum 1989-1994
Manually raising spoiler without a switch?
Old Aug 8, 2014 | 01:58 AM
blkmkiii's Avatar
blkmkiii
Default Manually raising spoiler without a switch?
So I picked up a 964 and the decklid will not open. I've been through everything. Someone posted on my last thread about how to open it that you can up the wing.Yeaaaa well my 1989 doesn't have that button in the center console.
What I am hoping for is the ability to hook up a power probe to the wing and get on my way.
Old Aug 8, 2014 | 02:33 AM
Andy Roe's Avatar
Andy Roe
The 89's had a switch actually under the spoiler itself I think. Not sure exactly where it is as my car is a later one, but if you lift the engine lid and have a look underneath it you should see the switch.
Old Aug 8, 2014 | 12:47 PM
blkmkiii's Avatar
blkmkiii
Decklid is 100% stuck closed.
Old Aug 8, 2014 | 04:31 PM
onceover's Avatar
onceover
I believe there is a manual release for the lid behind one of the tail lights
Old Aug 8, 2014 | 04:34 PM
LouZ's Avatar
LouZ
From: Philly Area ----- George Washington took a dump in my backyard!
Not on the early models. I added one, front and rear, to my '90 just in case.
Old Aug 8, 2014 | 04:47 PM
Andy Roe's Avatar
Andy Roe
AH, sorry - I thought you couldn't raise the spoiler.
So the engine lid won't open? Has the release cable snapped (and is slack) or do you think the lock has jammed? If you think that the cable is OK, have someone pull the release cable whilst also banging on the engine lid with the palm of your hand above where the lock would be to see if you can release the lock.
Old Aug 9, 2014 | 03:21 AM
klr10's Avatar
klr10
Spoiler controller wiring (from another thread)
#1 NC
#2 NC
#3 blue/green (spoiler motor - up)
#4 yellow/green (spoiler motor - down)
#5 brown (ground)
#6 red (battery 12v)
#7 orange (ignition 12v)
#8 green (warning light)
#9 green/red (up limit)
#10 green/black (down limit)
#11 brown/green (console switch common)
#12 white/red (speed signal)
Old Sep 9, 2014 | 01:34 AM
blkmkiii's Avatar
blkmkiii
perfect!
