964 plug & play ECU
#47
Very cool, excited to hear how this works for you guys.
#50
This is getting interesting, Rob with Typhoon and Alex with VEM's who will be the first to have theirs up and running first!
It's almost like the race to Space.
Looking forward to the updates.
#51
Raceboy, Ducks964 would one of you be willing to share the dwell data for bosch 0221503002 coil pack (I'm planning ahead)
Also do you know if these coil packs have the coil drivers built-in? ie they're triggered by simple low current.
#57
#58
50% OFF AT THE MOMENT.
THESE LOOK VERY DIFFERENT TO THE ONES GUS HAS USED. IS THERE ANY DIFFERENCE AND DO THEY HAVE TO BE OF ANY PARTICULAR CRITERIA?
SORRY IF THIS IS A DUMB QUESTION.
#59
You will also need adaptors for the plug wires, a bracket to hold the coils, and a distributor block off. Clewett Engineering has a distributor block off.
I have attached pictures of the adaptors needed.
#60
Thanks Ducks, they look simple enough to make.
The wiring connector on the coil pack, bosch pdf calls it a 'Jetronic'. Is that in fact a regular 'Junior Power Timer' 4-way? as it looks just like it.
