Help with shims
Help with shims
Ey all, looking for a bit of help so I don't waste money on something that's wrong. I'm running standard suspension and brakes on my c4. I also have cup 1 wheels on the car again all standard stuff but I would like the wheels to come a bit closer to the arches without rubbing (can be bothered with rubbing) , the car itself is lowered a bit but not to a massive degree.
Any help would be appreciated with both front and back.
Cheers
David
Cheers
David
Easiest way I find is to grab a tape measure and measure how much farther you want the wheel to sit out. From there just pick a brand of spacer and slap it on.
If you're extending them out quite far, be sure to get longer wheel studs. I believe at least 9 threads of engagement are required
Please give us some more info on the rim/tire sizes you are running now, that will make it a lot easier to recommend spacer width.
We need rim width and ET.
