Elephant racing front strut bar (935 style)
![](http://www.elephantracing.com/suspension/strutbrace/media/993-quickchange-strut-brace-main.jpg)
http://www.elephantracing.com/suspen...trut-brace.htm
I know some of you were interested in these from a discussion a few weeks back, I dont recall where.
at any rate Elephant Racing now offers one for 964 and 993. Love their products, always top notch.
![typing](https://rennlist.com/forums/graemlins/yltype.gif)
Former Vendor
Glad you guys like it. The brace has a quick-release feature that allows tool-less removal and installation.
The bar is secured with ball-spring detent pins. Pull the pins and the bars come out for access to the trunk area. Here it is the 911 version in operation. 964 version works the same way:
I have mentioned this a few times after seeing the D Zug version and wondering abouot 964 fitment
This looks very nice, but how rigid is it, if you can just pull a few pins out to remove it?
Re: the price, considering a set of rear lights is £600ish I think this isn't bad value considering the safety factor and assumed protection to the 964 tub
I can only speak for myself but factors such as safety, practicality and additional structural rigidity are a long way down my list with this...
At the top of said list is that it LOOKS flippin' awesome :-)
Former Vendor
The quick release pins do not degrade the rigidity of the system. The entire brace is based on achieving rigidity through triangulation.
The following is excerpted from an explanation of the importance of triangulation in chassis design on our website here
Rigidity in chassis design is typically achieved through the shape of the structure. In most designs, triangulation is the basic tool for creating rigidity through shape. A simple example illustrates how triangulation creates rigidity through shape;
![](http://elephantracing.com/images/strutbrace/parrallelagram.gif)
When forces are applied to a four-sided structure with corner pivots it can be easily forced out of shape. This structure is non-rigid.
![](http://elephantracing.com/images/strutbrace/triangulationanim.gif)
By adding a diagonal member, connected corners are held at a fixed distance. They can't be spread apart or moved closer together. Despite pivots for corners, the structure cannot be be forced out of shape, and is rigid. Notice that the additional member has formed two triangles in the structure. This is called triangulation.
In the simple example the shape creates rigidity, not the strength of the material. Pivots in the corners ensure individual structural members are not subjected to bending loads. Structural members are placed in pure tension or pure compression.
In response to some comments on safety.....[lawyer mode] the 935 X brace is not designed or intended to be a safety device [/lawyer mode]
Former Vendor
